Device Management
This document explains how to enable adaptive device (board type) support using EEPROM, including the steps to add new board types and implement adaptive booting.
For simplicity, the terms "device" and "board type" are used interchangeably throughout the following documentation.
Adding a New Device
The following example demonstrates how to add support for k1-x_MUSE-Pi board type.
Kernel Device Tree
When referring to the design of the deb1 hardware, copy k1-x_deb1.dts to the following location and modify the relevant content accordingly:
target/linux/spacemit/dts/k1-x_MUSE-Pi.dts
For the newly added board type, the .dts files are stored in the above directory. During compilation, they are packaged into the bootfs partition and loaded by U-Boot before the kernel boots.
U-Boot Device Tree
To add a new board type, the U-Boot source code repository needs to be modified as follows:
- Add the U-Boot device tree
u-boot-2022.10/arch/riscv/dts/k1-x_MUSE-Pi.dts. - Modify the Makefile to include
k1-x_MUSE-Pi.dtbas follows: (Note that the suffix should be changed to.dtb).
11 dtb-$(CONFIG_TARGET_SPACEMIT_K1X) += k1-x_evb.dtb k1-x_deb2.dtb k1-x_deb1.dtb k1-x_hs450.dtb \
12 k1-x_kx312.dtb k1-x_MINI-PC.dtb k1-x_mingo.dtb k1-x_MUSE-N1.dtb \
13 k1-x_MUSE-Pi.dtb k1-x_spl.dtb k1-x_milkv-jupiter.dtb \
14 k1-x_MUSE-Book.dtb
15
- Modify
uboot-2022.10/board/spacemit/k1-x/configs/uboot_fdt.its, add new node as follows:
@@ -46,15 +46,6 @@
algo = "crc32";
+ fdt_4 {
+ description = "k1-x_MUSE-Pi";
+ type = "flat_dt";
+ compression = "none";
+ data = /incbin/("../dtb/1-x_MUSE-Pi.dtb");
+ hash-1 {
+ algo = "crc32";
configurations {
@@ -74,10 +65,5 @@
loadables = "uboot";
fdt = "fdt_3";
+ conf_4 {
+ loadables = "uboot";
+ fdt = "fdt_4";
- Modify
uboot-2022.10/include/configs/k1-x.hand updateDEFAULT_PRODUCT_NAME. By default, FSBL and U-Boot will load the device tree blob (dtb) based onDEFAULT_PRODUCT_NAME. However, if the board has an EEPROM that stores information such as product_name, this will take precedence, and FSBL and U-Boot will use the EEPROM data to enable adaptive booting.
@@ -25,7 +25,7 @@
#define CONFIG_GATEWAYIP 10.0.92.1
#define CONFIG_NETMASK 255.255.255.0
-#define DEFAULT_PRODUCT_NAME "k1_deb1"
+#define DEFAULT_PRODUCT_NAME "k1-x_MUSE-Pi"
#define K1X_SPL_BOOT_LOAD_ADDR (0x20200000)
#define DDR_TRAINING_DATA_BASE (0xc0829000)
Add Support for New Board
If it is a development board form factor, modify openwrt/target/linux/spacemit/image/k1-sbc.mk to add support for the k1-x_MUSE-Pi board type.
DEVICE_DTS := k1-x_deb1 k1-x_MUSE-Pi
If it is necessary to add a new configuration, please refer to Solution Management.
Support Single CS DDR
By default, FSBL supports dual CS DDR. To enable support for single CS DDR, modify uboot-2022.10/arch/riscv/dts/k1-x_spl.dts.
@@ -79,7 +79,7 @@
ddr@c0000000 {
/* dram data rate, should be 1200, 1600, or 2400 */
datarate = <2400>;
- cs-num = <2>;
+ cs-num = <1>;
u-boot,dm-spl;
If the device has an EEPROM, adaptive support can be enabled through it. The relevant key name is ddr_cs_num, which can be programmed using the Titan Flash Tool. Please refer Flash Tool for more details.
Adaptive Booting via EEPROM
Use the Titan Flash Tool to program the board's EEPROM, enabling adaptive booting — that is, allowing a single firmware to support multiple board types.
During system startup, the information stored in the EEPROM is read and matched with the data in uboot_fdt.its, thereby supporting multiple board types.
Relevant Files:
uboot-2022.10/arch/riscv/dts/k1-x_*.dts
EEPROM Support List
atmel,24c02
Add New EEPROM
- Modify
uboot-2022.10/arch/riscv/dts/k1-x_spl.dtsto update the I2C address of the EEPROM — for example, set the new address to 0xA0.0xA0.
@@ -121,7 +121,7 @@
eeprom@50{
compatible = "atmel,24c02";
u-boot,dm-spl;
reg = <0x50>;
reg = <0xA0>;
bus = <6>;
#address-cells = <1>;
#size-cells = <1>;
Modify
uboot-2022.10/arch/riscv/dts/k1-x_*.dtsto add the new EEPROM configuration:@@ -60,9 +60,9 @@
pinctrl-0 = <&pinctrl_i2c2_0>;
- eeprom@50{
- compatible = "atmel,24c02";
- reg = <0x50>;
+ eeprom@A0{
+ compatible = "atmel,24c04";
+ reg = <0xA0>;
vin-supply-names = "eeprom_1v8";
Use tlv_eeprom Command to Write Keys
Writing to the EEPROM involves storing information such as product_name. Currently, the data in the EEPROM is encoded using the TLV format, and the tlv_eeprom command provided by u-boot can be used to perform this operation.
Connect the user's PC to the device's debug serial port. During boot-up press the
skey on the PC terminal to enter the u-boot shell.Autoboot in 0 seconds
write
product_name,such ask1-x_MUSE-Pi。=> tlv_eeprom set 0x21 k1-x_MUSE-Pi
=> tlv_eeprom write
Programming passed.Programming passed.meaning write key success.Use the name of the device’s DTS file (without the extension, e.g., k1-x_MUSE-Pi) to enable automatic loading of the DTB by u-boot.
Reboot the device and check if the
k1-x_MUSE-PiDTB is loaded. If everything works correctly, u-boot should print the following:Boot from fit configuration: k1-x_MUSE-Pi
The SDK also supports reading the following information from the EEPROM:
- Serial Number:
0x23 - Base MAC Address:
0x24 - Manufacture Date:
0x25 - Device Version:
0x26 - MAC Addresses:
0x2A - Manufacturer:
0x2B - SDK Version:
0x40
The MAC address will be updated in the DTB and used as the physical address of the network card.
