ISP API Development Guide
This document explains the SDK API interfaces.
ISP API
This section introduces the usage of ISP module APIs. These APIs are part of the ISP SDK aimed at applications, mainly divided into:
- System Control APIs
- Image Effect Setting APIs
- Tuning-related APIs
It provides detailed explanations of relevant parameter data structures, error codes, and return values. The primary audience includes tuning and algorithm engineers focused on ISP effects, as well as application engineers developing image-related functionalities.
System Control APIs
These APIs manage the overall operation of the ISP pipeline. They are primarily used by image processing, tuning, and application engineers.
- ASR_ISP_Construct: Constructs the ISP pipeline context environment.
- ASR_ISP_Destruct: Destroys the ISP pipeline context environment.
- ASR_ISP_GetFwFrameInfoSize(): Retrieves the size of the ISP firmware frame info structure.
- ASR_ISP_RegSensorCallBack: Registers a sensor callback function to the ISP pipeline.
- ASR_ISP_UnRegSensorCallBack: Unregisters a sensor callback from the ISP pipeline.
- ASR_ISP_RegAfMotorCallBack: Registers an autofocus motor callback to the ISP pipeline.
- ASR_ISP_EnableOfflineMode: Enables the ISP pipeline’s offline mode.
- ASR_ISP_SetPubAttr: Sets public attributes for the ISP pipeline.
- ASR_ISP_SetTuningParams: Sets tuning-related parameters for the ISP pipeline.
- ASR_ISP_SetChHwPipeID: Sets the actual hardware pipe ID for the pipeline channel.
- ASR_ISP_Init: Initializes the ISP pipeline.
- ASR_ISP_DeInit: Deinitializes the ISP pipeline.
- ASR_ISP_EnablePDAF: Enables PDAF (Phase Detection Auto Focus) in the ISP pipeline.
- ASR_ISP_SetFps: Sets the frame rate for the sensor/ISP on this pipeline.
- ASR_ISP_SetFrameinfoCallback: Sets the callback function for receiving frame info.
- ASR_ISP_QueueFrameinfoBuffer: Queues a frame info buffer in the pipeline.
- ASR_ISP_FlushFrameinfoBuffer: Flushes the frame info buffer queue.
- ASR_ISP_Streamon: Starts the streaming process in the ISP pipeline.
- ASR_ISP_Streamoff: Stops the streaming process in the ISP pipeline.
- ASR_ISP_TriggerRawCapture: Triggers a raw capture process.
- ASR_ISP_ReInitPreviewChannel: Reinitializes the preview channel.
- ASR_ISP_NotifyOnceHDRRawCapture: Notifies the pipeline to perform a single HDR raw capture.
- ASR_ISP_UpdateNoneZslStreamAeParams: Updates AE (Auto Exposure) parameters for non-ZSL streams.
ASR_ISP_Construct
[Description] Constructs the ISP pipeline context.
[Syntax]
int ASR_ISP_Construct(uint32_t pipelineID);
[Parameters]
| Name | Description | In/Out |
| pipelineID | ID of the ISP pipeline | Input |
[Return Value]
| Value | Description |
| 0 | Success |
| Non-0 | Failure (error code) |
[Requirements]
- Header file:
spm_cam_isp.h - Library:
libisp.so
[Note]
- The
pipelineIDparameter refers to a virtual pipeline, each mapping to one ISP firmware instance.
ASR_ISP_Destruct
[Description] Destructs (destroys) the ISP pipeline context.
[Syntax]
int ASR_ISP_Destruct(uint32_t pipelineID);
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Description]
Gets the size of the ISP Firmware frameinfo structure.
[Syntax]
int ASR_ISP_GetFwFrameInfoSize(void);
[Parameters]
None.
[Return Value]
| Return Value | Description |
| >0 | Size of the structure |
| <0 | Failure (error code value) |
[Requirements]
- Header file:
spm_cam_isp.h - Library file:
libisp.so
[Description]
[Syntax]
int ASR_ISP_RegSensorCallBack(
uint32_t pipelineID,
ISP_SENSOR_ATTR_S *pstSensorInfo,
ISP_SENSOR_REGISTER_S *pstRegister
[Parameters]
| Parameter Name | Description | Input/Output |
| pstSensorInfo | Attributes of the sensor being registered | Input |
| pstRegister | Pointer to the structure of sensor callbacks | Input |
[Return Value]
| 0 | Success |
| Non-0 | Failure (error code value) |
[Requirements]
- Header files:
spm_cam_isp.h,spm_isp_sensor_comm.h - Library files:
libisp.so,libcam_sensors.so
[Description] Unregisters the sensor callback function from the ISP pipeline.
[Syntax]
int ASR_ISP_UnRegSensorCallBack(
[Parameters]
| pstSensorInfo | Attributes of the sensor to be unregistered | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
spm_cam_isp.h,spm_isp_sensor_comm.h - Library file:
libisp.so
[Description]
Registers the sensor AF (autofocus) motor callback function to the ISP pipeline.
[Syntax]
int ASR_ISP_RegAfMotorCallBack(
ISP_AF_MOTOR_REGISTER_S *pstAfRegister
[Parameters]
| pstAfRegister | Pointer to the sensor AF motor callback function structure | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Description]
Enables the ISP pipeline Offline mode, where the ISP input stream comes from DDR instead of the sensor, and the VI module reads data from DDR.
[Syntax]
Int ASR_ISP_EnableOfflineMode(
uint32_t enable,
const ISP_OFFLINE_ATTR_S *pstOfflineAttr
[Parameters]
| enable | Enable/disable offline mode | Input |
| pstOfflineAttr | Pointer to the Offline mode attribute struct | Input |
[Return Value]
| Parameter | Description |
| 0 | Success |
[Requirements]
- Header files:
spm_cam_isp.h,spm_isp_comm.h - Library file:
libisp.so
[Note]
- When offline mode is enabled, sensor and motor callbacks do not need to be registered; even if registered, the ISP will not use them.
- In special photo-taking scenarios, the offline pipeline processing does not require using this function.
ASR_ISP_SetPubAttr
[Description]
Sets the public attributes of a channel on the ISP pipeline.
[Syntax]
int ASR_ISP_SetPubAttr(
uint32_t channelID,
const ISP_PUB_ATTR_S *pstPubAttr
[Parameters]
| pipelineID | ISP pipeline ID | Input |
| channelID | ID of the ISP pipeline channel | Input |
| pstPubAttr | Pointer to the ISP pipeline public attribute structure | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Description]
Sets tuning-related attributes on the ISP pipeline. To facilitate algorithm development and debugging, the ISP initialization tuning parameters are determined by two parts:
- Parameters first obtained from the sensor side (by converting pre-tuned files into code);
- If this interface informs the ISP that a tuning file currently exists, the ISP will prioritize that file, overriding previously set parameters; otherwise, no operation is performed.
[Syntax]
int ASR_ISP_SetTuningParams(
ISP_TUNING_ATTRS_S *pstTuningAttr
[Parameters]
| pstTuningAttr | Pointer to the ISP pipeline tuning attribute structure | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
- Before calling this interface, either
ASR_ISP_RegSensorCallBackorASR_ISP_EnableOfflineModemust be called first.
[Description]
Sets the actual hardware pipe ID for the channel in the ISP pipeline.
[Syntax]
int ASR_ISP_SetChHwPipeID(
uint32_t channelID,
uint32_t hwPipeID
[Parameters]
| hwPipeID | Actual hardware pipe ID | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
- This interface must be called before
ASR_ISP_Init; otherwise, the ISP channel will start running with the default channel ID (hardware pipe 0). - The input parameter
pipelineIDcorresponds to the ISP firmware;channelIDcorresponds to the working mode (preview or capture);hwPipeIDcorresponds to the ISP hardware pipeline ID. For special photo-taking scenarios, a single firmware can manage two hardware pipelines working in different modes, ensuring consistent image quality across both hardware pipelines.
ASR_ISP_Init
[Description]
Initializes the ISP pipeline with previously set parameters. After initialization, all parameters for the first frame are ready. In principle, it is not recommended to set initialization parameters after this interface call, as changes will not take effect in the first frame but only from the second frame onward.
[Syntax]
int ASR_ISP_Init(
uint32_t pipelineID
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
ASR_ISP_DeInit
[Description]
Deinitializes the ISP pipeline, clearing all effect parameters set on the pipeline. Some registered callbacks will not be cleared.
[Syntax]
int ASR_ISP_DeInit(
uint32_t pipelineID
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
ASR_ISP_EnablePDAF
[Description]
Enables or disables the PDAF function of the ISP pipeline.
[Syntax]
int ASR_ISP_EnablePDAF(
uint32_t enable
[Parameters]
| enable | Flag to enable or disable PDAF | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
- Must be called after
ASR_ISP_Init.
ASR_ISP_SetFps
[Description]
Sets the frame rate of the ISP pipeline. The ISP supports dynamic frame rates. To run at a specific fixed frame rate, set both fminFps and fmaxFps to the same value. This interface can be called either before ASR_ISP_Init or while the ISP is running; in the former case, the first frame will run at the set frame rate.
[Syntax]
int ASR_ISP_SetFps(
float fminFps,
float fmaxFps
[Parameters]
| fminFps | Minimum frame rate | Input |
| fmaxFps | Maximum frame rate | Input |
[Return Value]
| 0 | Success |
| Non-0 | Failure, error code |
[Requirements]
- Header files:
libisp.so
[Description]
Sets the callback function for notifying the user to obtain frameinfo of the ISP pipeline. The ISP sends the frameinfo to the user via this callback each time it updates the frameinfo of a frame.
[Syntax]
int ASR_ISP_SetFrameinfoCallback(
GetFrameInfoCallBack callback
[Parameters]
| callback | User callback function to obtain frameinfo | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Description]
Function to enqueue the frameinfo buffer of the ISP pipeline. The ISP internally uses the frameinfo buffer as a queue, operating in a first-in-first-out (FIFO) manner.
[Syntax]
int ASR_ISP_QueueFrameinfoBuffer(
IMAGE_BUFFER_S *pFrameInfoBuf
[Parameters]
| pFrameInfoBuf | FrameInfo buffer | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
spm_cam_isp.h,cam_module_interface.h - Library file:
libisp.so
[Note]
- The input parameter pointer
pFrameInfoBufis used directly by the SDK. Therefore, the application layer must ensure that the memory pointed to by this pointer is not released until the registered callback function is called.
[Description]
Clears the frameinfo buffer queue on the ISP pipeline. Buffers that are cleared are returned via the registered callback.
[Syntax]
int ASR_ISP_FlushFrameinfoBuffer(
uint32_t pipelineID
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
- Do not enqueue buffers that have been flushed, as this may cause deadlock issues.
ASR_ISP_Streamon
[Description]
Runs the ISP pipeline. The sensor's streamon must be called after this function.
[Syntax]
int ASR_ISP_Streamon(
uint32_t pipelineID
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
ASR_ISP_Init. - Do not start the sensor before this call.
ASR_ISP_Streamoff
[Description]
Stop the ISP pipeline operation.
[Syntax]
int ASR_ISP_Streamoff(
uint32_t pipelineID
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
ASR_ISP_Streamon.
[Description]
Triggers the ISP pipeline to perform a special capture process for specific photo scenarios. If a capture is already in progress, this call will fail.
[Syntax]
int ASR_ISP_TriggerRawCapture(
IMAGE_BUFFER_S *pFrameInfoBuf,
uint32_t hdrCapture
[Parameters]
| pFrameInfoBuf | The frameinfo buffer corresponding to the current RAW image. This frameinfo should be the same as the preview frame’s frameinfo during capture; otherwise, the image quality of the capture may differ from the preview. | Input |
| hdrCapture | Flag indicating whether this is an HDR capture. Currently, HDR capture in this system only supports HDR synthesis in the RAW domain. | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Note]
- This function is valid only when the ISP pipeline is running.
[Description]
Reinitialize the preview channel of the ISP pipeline. In some scenarios, the preview of a pipeline may be stopped to reuse the hardware pipe. When restoring the preview, this function needs to be called to ensure the image quality before and after the stream interruption remains consistent.
[Syntax]
int ASR_ISP_ReInitPreviewChannel(
[Parameters]
| pFrameInfoBuf | The frameinfo buffer for the scene to be restored | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
[Description]
Notify the ISP pipeline to perform an HDR Raw capture process. The ISP returns the valid Raw frame ID of the first HDR frame. Currently, the HDR Raw frame order is normal exposure, long exposure, and short exposure.
[Syntax]
int ASR_ISP_NotifyOnceHDRRawCapture(
uint32_t ZSLCapture,
int32_t *startFrameID
[Parameters]
| ZSLCapture | Flag indicating whether this is a ZSL HDR capture | Input |
| startFrameID | Stores the frame ID of the first valid HDR Raw frame | Output |
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Note]
- This interface can only be called while the ISP is running.
[Description]
Updates the sensor AE-related parameters on the ISP pipeline. This interface is only useful when restarting the pipeline after a stream interruption, to keep the sensor state consistent before and after the interruption.
[Syntax]
int ASR_ISP_UpdateNoneZslStreamAeParams(
int backPreview,
int updateSnsReg
[Parameters]
| pFrameInfoBuf | Frameinfo corresponding to the state that needs to be updated | Input |
| backPreview | Flag indicating whether to switch preview | Input |
| updateSnsReg | Flag indicating whether the sensor’s AE registers need to be updated. This should be enabled after the sensor is reconfigured; otherwise, it is not necessary. | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libisp.so
Effect Setting API
This section describes APIs designed to help users configure settings related to image effects. In this software, image effect settings are implemented via commands. These commands are exposed through a unified API interface:
- ASR_ISP_SetEffectParams: Interface to set effect parameters related to the ISP pipeline.
The supported effect commands by the ISP are as follows:
- ISP_EFFECT_CMD_S_AE_MODE
- ISP_EFFECT_CMD_S_AWB_MODE
- ISP_EFFECT_CMD_S_AF_MODE
- ISP_EFFECT_CMD_S_TRIGGER_AF
- ISP_EFFECT_CMD_S_ANTIFLICKER_MODE
- ISP_EFFECT_CMD_S_LSC_MODE
- ISP_EFFECT_CMD_S_CCM_MODE
- ISP_EFFECT_CMD_S_AECOMPENSATION
- ISP_EFFECT_CMD_S_METERING_MODE
- ISP_EFFECT_CMD_S_ZOOM_RATIO_IN_Q8
- ISP_EFFECT_CMD_S_SENSITIVITY_MODE
- ISP_EFFECT_CMD_S_SENSOR_EXPOSURE_MODE
- ISP_EFFECT_CMD_S_TRIGGER_AE_QUICK_RESPONSE
- ISP_EFFECT_CMD_S_AECOMPENSATION_STEP
- ISP_EFFECT_CMD_S_AE_SCENE_MODE
- ISP_EFFECT_CMD_S_FILTER_MODE
- ISP_EFFECT_CMD_S_YUV_RANGE
- ISP_EFFECT_CMD_S_SOLID_COLOR_MODE
- ISP_EFFECT_CMD_G_AF_MODE
- ISP_EFFECT_CMD_G_ANTIFLICKER_MODE
- ISP_EFFECT_CMD_G_METERING_MODE
- ISP_EFFECT_CMD_G_AF_MOTOR_RANGE
- ISP_EFFECT_CMD_G_AE_MODE
- ISP_EFFECT_CMD_G_AWB_MODE
[Description]
Interface to set ISP image effect parameters.
[Syntax]
int ASR_ISP_SetEffectParams(
uint32_t effectCmd,
void *pData,
int dataSize
[Parameters]
| effectCmd | Effect parameter command | Input |
| pData | Pointer to the effect parameter structure | Input |
| dataSize | Size of the effect parameter structure | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
Effect Command Descriptions
Command to set image exposure mode. The corresponding parameter type is the structureasrISP_AE_INFO_S. -
Command to set image white balance mode. The corresponding parameter type is the structureasrISP_AWB_INFO_S. -
Command to set image autofocus mode. The corresponding parameter type is the structureasrISP_AF_INFO_S. -
Command to trigger autofocus. The corresponding parameter type isint32_t. A value of1triggers autofocus, and0cancels it. -
Command to set the image anti-flicker mode. The corresponding parameter type isint32_t, and the value is defined by the enumasrISP_ANTIFLICKER_MODE_E. -
Command to set the lens shading correction mode. The corresponding parameter type is the structureasrISP_LSC_INFO_S. -
Command to set the color correction matrix (CCM) mode. The corresponding parameter type is the structureasrISP_CCM_INFO_S. -
Command to set the exposure compensation. The corresponding parameter type isint32_t, with a currently supported range of [-6, 6]. -
Command to set the metering mode. The corresponding parameter type is the structureasrISP_METERING_INFO_S. -
Command to set the zoom ratio. The corresponding parameter type isint32_t, with the unit in Q8 format. -
Command to set the ISO sensitivity mode. The corresponding parameter type is the structureasrISP_SENSITIVITY_INFO_S, which supports both auto and manual modes. -
- Command to set the sensor exposure mode. The difference between this and
ISP_EFFECT_CMD_S_AE_MODEis that this command only sets exposure information, while the other also sets gain information. - The corresponding parameter type is the structure
asrISP_SENSOR_EXPOSURE_INFO_S, supporting both auto and manual modes. - The relationship among these three commands (
ISP_EFFECT_CMD_S_SENSOR_EXPOSURE_MODE,ISP_EFFECT_CMD_S_AE_MODE, andISP_EFFECT_CMD_S_SENSITIVITY_MODE) is shown in the table below (not included here).
| AE MODE | SENSITIVITY AUTO | SENSITIVITY MANUAL |
| SENSOR EXPOSURE AUTO | Auto | Auto |
| SENSOR EXPOSURE MANUAL | Auto | Manual |
- As shown in the table above,
SENSITIVITY_MODE_MANUALmeans that under Auto Exposure, the gain is fixed, and exposure is automatically calculated by the algorithm based on the scene; whileSENSOR_EXPOSURE_MODE_MANUALmeans that under Auto Exposure, the exposure time is fixed, and gain is automatically calculated by the algorithm.
Command to trigger a quick AE convergence once. The corresponding parameter type isint32_t, where1triggers and0cancels. This command only takes effect once. After quick AE convergence, the algorithm clears this state. Typically used in touch scenarios. -
Sets the exposure compensation step value in ISP. Parameter type:float. After setting, exposure compensation will be adjusted in steps according to this value. The default is 1/3. -
Sets the AE scene mode of the ISP. Parameter type:int32_t, with values defined by the enumasrISP_AE_SCENE_MODE_E. Supported modes include Normal and Face Detection. In Face Detection mode, AE converges faster than in Normal mode. -
Sets the ISP color filter mode. Parameter type:int32_t, defined by enumasrISP_COLOR_FILTER_MODE_E. Currently supports Normal and Black & White modes. Default is Normal. -
Sets the YUV range of the ISP. Parameter type:int32_t, defined by enumasrISP_YUV_RANGE_E. Supported modes:- Full: y:0
255, uv:0255 - Compressed: y:16
235, uv:16240
- Full: y:0
Sets the ISP solid color mode. Parameter type:int32_t, defined by enumasrISP_SOLID_COLOR_MODE_E. Currently only supports solid black mode. This mode is disabled by default. -
Gets the current AF mode of the ISP. Parameter type: structasrISP_AF_INFO_S. -
Gets the current anti-flicker mode of the ISP. Parameter type:int32_t, defined by enumasrISP_ANTIFLICKER_MODE_E. -
Gets the current metering mode of the ISP. Parameter type: structasrISP_METERING_INFO_S. -
Gets the range of movement of the autofocus motor (min and max values). Parameter type: structasrISP_RANGE_S. -
Gets the current AE mode of the ISP. Parameter type: structISP_AE_INFO_S. -
Gets the current AWB mode of the ISP. Parameter type: structISP_AWB_INFO_S.
Tuning-Related API
This section describes APIs intended to help tuning engineers adjust more specific and detailed parameters. The tuning tool released by ASR also uses the APIs described in this section.
The tuning-related APIs are as follows:
ASR_ISP_SetFwPara:
Set firmware parameters on the ISP pipeline. -
ASR_ISP_GetFwPara:
Get firmware parameters from the ISP pipeline. -
ASR_ISP_SetRegister:
Set the value of a specified register. -
ASR_ISP_GetRegister:
Get the value of a specified register. -
ASR_ISP_LoadSettingFile:
Load a setting file into the firmware on the ISP pipeline. -
ASR_ISP_SaveSettingFile:
Save the current firmware setting file from the ISP pipeline.
ASR_ISP_SetFwPara
[Description]
Sets a parameter in the ISP firmware.
[Syntax]
int ASR_ISP_SetFwPara(
const char *parameter,
const char *name,
uint32_t row,
uint32_t column,
int value
[Parameters]
| paramter | Name of the ISP submodule | Input |
| name | Parameter name | Input |
| row | Row number | Input |
| column | Column number | Input |
| value | Value | Input |
[Return Value]
| 0 | Success |
| Non-0 | Failure, the (error code value) |
[Requirements]
- Header file:
libisp.so
[Note] None
ASR_ISP_GetFWPara
[Description]
Gets ISP Firmware parameters.
[Syntax]
int ASR_ISP_GetFWPara(
const char *paramter,
const char *name,
uint32_t row,
uint32_t column,
int *pValue
[Parameters]
| value | Value | Output |
[Return Value]
| -1 | Input check error |
| 0 | Specified parameter not found |
| >0 | Success, returns the number of values obtained |
[Requirements]
- Header file:
libisp.so
[Note] None
ASR_ISP_SetRegister
ASR_ISP_SetRegister
[Description]
Sets the specified register value.
[Syntax]
int ASR_ISP_SetRegister(
uint32_t addr,
uint32_t value,
uint32_t mask
[Parameters]
| addr | Register address | Input |
| value | Register value | Input |
| mask | Register mask | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Note] None
ASR_ISP_GetRegister
[Description]
Gets the value of the specified register.
[Syntax]
int ASR_ISP_GetRegister(
uint32_t addr,
int *pValue
[Parameters]
| pValue | Register value | Output |
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Note] None
[Description]
Loads the ISP Firmware setting file.
[Syntax]
int ASR_ISP_LoadSettingFile(
const char *pFileName
[Parameters]
| pFileName | Parameter file name, including absolute path | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Note]
None
[Description]
Saves the ISP Firmware setting file.
[Syntax]
int ASR_ISP_SaveSettingFile(
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header file:
libisp.so
[Note]
None
Main API Usage Flow
This section mainly describes the usage flow of the system control API, which is divided into the following stages: construction, registration, setting, initialization, streamon, streamoff, de-initialization, and destruction.
Construct the context environment of the ISP pipeline.
Registration: Register the sensor callback function, autofocus motor callback function, and frameinfo callback function to the ISP pipeline.
Setting: Configure the ISP pipeline's common image properties, tuning-related properties, the actual hardware pipe ID used by the channel, frame rate, whether to enable offline mode, and enqueue the frameinfo buffer.
Initialization: Initialize the ISP pipeline based on the information set in the previous steps.
Streamon: Start the ISP pipeline and enter the working state.
Streamoff: Stop the ISP pipeline operation and exit the working state.
De-initialization: Clear the set parameters and other information (except the previously registered callbacks).
Destruction: Destroy the context environment of the ISP pipeline.
The above process is pipeline-oriented. The ISP software can support two pipelines working simultaneously. If another pipeline needs to be started, the process is similar, but attention should be paid to the actual hardware pipe ID in use, as sometimes resources are shared.
Data Types
Error Codes
| Error Code | Macro Definition | Description |
| -22 | ASR_ERR_ISP_ILLEGAL_PARAM | Illegal parameter |
| -17 | ASR_ERR_ISP_EXIST | Resource already exists |
| -19 | ASR_ERR_ISP_NOTEXIST | Resource does not exist |
| -22 | ASR_ERR_ISP_NULL_PTR | Null pointer |
| -1 | ASR_ERR_ISP_NOT_SUPPORT | Operation not supported |
| -1 | ASR_ERR_ISP_NOT_PERM | Operation not permitted |
| -12 | ASR_ERR_ISP_NOMEM | Insufficient memory |
| -14 | ASR_ERR_ISP_BADADDR | Invalid address |
| -16 | ASR_ERR_ISP_BUSY | System busy |
VI API
This section introduces the usage of the ASR MARS11-ISP VI module APIs. The described APIs are part of the VI SDK designed for applications, with detailed explanations of related parameter data structures and return values.
APIs
The VI module provides the following APIs:
- ASR_VI_SetDevAttr: Sets the attributes of the VI Device.
- ASR_VI_GetDevAttr: Gets the attributes of the VI Device.
- ASR_VI_EnableDev: Enables the VI Device.
- ASR_VI_DisableDev: Disables the VI Device.
- ASR_VI_SetChnAttr: Sets the attributes of the VI Channel.
- ASR_VI_GetChnAttr: Gets the attributes of the VI Channel.
- ASR_VI_SetCallback: Sets the upper-layer Callback function to the VI Device.
- ASR_VI_EnableChn: Enables the VI Channel.
- ASR_VI_DisableChn: Disables the VI Channel.
- ASR_VI_Init: Initializes VI module resources.
- ASR_VI_Deinit: Releases VI module resources.
- ASR_VI_SetBayerReadAttr: Sets the attributes for offline Bayer raw reading.
- ASR_VI_GetBayerReadAttr: Gets the attributes for offline Bayer raw reading.
- ASR_VI_EnableBayerRead: Enables offline Bayer raw reading.
- ASR_VI_DisableBayerRead: Disables offline Bayer raw reading.
- ASR_VI_EnableBayerDump: Enables Bayer Dump.
- ASR_VI_DisableBayerDump: Disables Bayer Dump.
- ASR_VI_ChnQueueBuffer: Queues a buffer into the channel.
ASR_VI_SetDevAttr
[Description]
Sets the VI device attributes. Basic device attributes have default chip configurations to meet the requirements of most sensor integrations.
[Syntax]
int32_t ASR_VI_SetDevAttr(
uint32_t nDev,
VI_DEV_ATTR_S *pstDevAttr
[Parameters]
| nDev | VI device number, valid range: [0, VIU_MAX_DEV_NUM) | Input |
| pstDevAttr | Pointer to VI device attributes. Static attributes. | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
spm_comm_vi.h,spm_cam_vi.h - Library file:
libvi.so
[Note]
- Changing the binding relationship between device and channel is not supported.
- Before calling, ensure the VI device is disabled. If the VI device is enabled, you can disable it using
ASR_CAM_VI_DisableDev.
ASR_VI_GetDevAttr
[Description]
Gets the VI device attributes.
[Syntax]
int32_t ASR_VI_GetDevAttr(
uint32_t nDev,
[Parameters]
| nDev | VI device number. Valid range: [0, VIU_MAX_DEV_NUM) | Input |
| pstDevAttr | Pointer to VI device attributes. | Output |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
ASR_VI_EnableDev
[Description]
Enables the VI device.
[Syntax]
int32_t ASR_VI_EnableDev(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- Device attributes must be set before enabling; otherwise, it returns failure.
- Can be enabled repeatedly without returning failure.
ASR_VI_DisableDev
[Description]
Disables the VI device.
[Syntax]
int32_t ASR_VI_DisableDev(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- All VI channels bound to the VI device must be disabled before disabling the VI device.
- Can be disabled repeatedly without returning failure.
ASR_VI_FlushDev
[Description]
Flushes the buffers that have been queued into the VI device.
[Syntax]
int32_t ASR_VI_FlushDev(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
ASR_VI_SetChnAttr
[Description]
Sets the VI channel attributes.
[Syntax]
int32_t ASR_VI_SetChnAttr(
uint32_t nChn,
VI_CHN_ATTR_S *pstAttr
[Parameters]
| nChn | VI channel number. Valid range: [0, VIU_MAX_CHN_NUM) | Input |
| pstAttr | Pointer to VI channel attributes. Static attributes. | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- Device attributes must be set before setting channel attributes; otherwise, it will return failure.
- The channel must be in the Disabled state to set channel attributes.
ASR_VI_GetChnAttr
[Description]
Gets the VI channel attributes.
[Syntax]
int32_t ASR_VI_GetChnAttr(
uint32_t nChn,
[Parameters]
| pstAttr | Pointer to VI channel attributes. Static attributes. | Output |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- Channel attributes must be set before getting them; otherwise, it will return failure.
ASR_VI_EnableChn
[Description]
Enables the VI channel.
[Syntax]
int32_t ASR_VI_EnableChn(
uint32_t nChn
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- Channel attributes must be set first, and the VI device bound to the channel must be enabled.
- VI channel can be enabled repeatedly without returning failure.
ASR_VI_DisableChn
[Description]
Disables the VI channel.
[Syntax]
int32_t ASR_VI_DisableChn(
uint32_t nChn
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- VI channel can be disabled repeatedly without returning failure.
ASR_VI_SetCallback
[Description]
Sets the callback function used for frame buffer rotation.
[Syntax]
int32_t ASR_VI_SetCallback(
uint32_t nChn,
int32_t (*callback)(uint32_t nChn, VI_IMAGE_BUFFER_S *vi_buffer)
[Parameters]
| callback | Pointer to the callback function | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- Must be called before
ASR_VI_EnableChn.
[Description]
Sets the attributes for offline raw Bayer data reading.
[Syntax]
int32_t ASR_VI_SetBayerReadAttr(
uint32_t nDev,
const VI_BAYER_READ_ATTR_S *pstBayerReadAttr
[Parameters]
| pstBayerReadAttr | Pointer to the Bayer read attribute structure | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Description]
Gets the attributes for offline raw Bayer data reading.
[Syntax]
int32_t ASR_VI_GetBayerReadAttr(
uint32_t nDev,
[Parameters]
| pstBayerReadAttr | Pointer to the Bayer read attribute structure | Output |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Description]
Enables offline processing.
[Syntax]
int32_t ASR_VI_EnableBayerRead(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Description]
Disables offline processing.
[Syntax]
int32_t ASR_VI_DisableBayerRead(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Description]
Enables RAW DATA capture.
[Syntax]
int32_t ASR_VI_EnableBayerDump(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
- The width and height of the saved RAW data are consistent with the width and height set for the device.
- The starting channel number for RAW Dump channels can be obtained via
VIU_GET_RAW_CHN.
[Description]
Disables RAW DATA capture.
[Syntax]
int32_t ASR_VI_DisableBayerDump(
uint32_t nDev
[Parameters]
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Description]
Queues a buffer to the channel.
[Syntax]
int32_t ASR_VI_ChnQueueBuffer(
uint32_t nChn,
IMAGE_BUFFER_S *camBuf
[Parameters]
| nChn | VI channel number. Valid range: [0, VI_CHN_CNT) | Input |
| camBuf | Pointer to the buffer | Input |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
[Note]
camBufpointer will be used directly by the SDK. Therefore, the application layer must ensure that the memory pointed to by this pointer is not freed until the registered callback function is called.
ASR_VI_Init
[Description]
Initializes the VI module.
[Syntax]
int32_t ASR_VI_Init(void);
[Parameters]
| None |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
ASR_VI_Deinit
[Description]
Deinitializes the VI module.
[Syntax]
int32_t ASR_VI_Deinit(void);
[Parameters]
| None |
[Return Value]
| 0 | Success |
[Requirements]
- Header files:
libvi.so
Data Types
VI_DEV_ATTR_S
[Description]
Defines the attributes of the video input device.
[Definition]
typedef struct asrVI_DEV_ATTR_S {
CAM_VI_WORK_MODE_E enWorkMode;
CAM_SENSOR_RAWTYPE_E enRawType;
uint32_t width;
uint32_t height;
uint32_t bindSensorIdx;
uint32_t mipi_lane_num;
bool bCapture2Preview;
} VI_DEV_ATTR_S;
[Members]
| Member Name | Description |
| enWorkMode | CAM_VI_WORK_MODE_ONLINE, CAM_VI_WORK_MODE_RAWDUMP, CAM_VI_WORK_MODE_OFFLINE |
| enRawType | CAM_SENSOR_RAWTYPE_RAW8, CAM_SENSOR_RAWTYPE_RAW10, CAM_SENSOR_RAWTYPE_RAW12, CAM_SENSOR_RAWTYPE_RAW14, CAM_SENSOR_RAWTYPE_INVALID |
| Width | The width of the image to capture settable by the VI device. The minimum and maximum capture width range: [VIU_DEV_MIN_WIDTH, VIU_DEV_MAX_WIDTH] |
| Height | The height of the image to capture settable by the VI device. The minimum and maximum capture height range: [VIU_DEV_MIN_HEIGHT, VIU_DEV_MAX_HEIGHT] |
| bindSensorIdx | Sensor ID bound to the VI device. Range: [0, 2] |
| bOfflineSlice | Whether offline mode is for photo capture |
| mipi_lane_num | Number of lanes of the sensor MIPI interface |
| bCapture2Preview | Whether it is photo capture back to preview |
VI_CHN_ATTR_S
[Description]
Defines the attributes of a VI channel.
[Definition]
typedef struct asrVI_CHN_ATTR_S {
CAM_VI_PIXEL_FORMAT_E enPixFormat;
uint32_t width;
uint32_t height;
} VI_CHN_ATTR_S;
[Members]
| enPixFormat | Channel output format |
| Width | Output image width |
| Height | Output image height |
[Description]
Defines the attributes for offline raw data reading.
[Definition]
typedef struct asrVI_BAYER_READ_ATTR_S {
bool bGenTiming;
int32_t s32FrmRate;
} VI_BAYER_READ_ATTR_S;
[Members]
| bGenTiming | Whether VI automatically generates fixed frame rate reading timing |
| s32FrmRate | If bGenTiming is true, indicates the frame rate value |
VI_IMAGE_BUFFER_S
[Description]
Defines the structure of the buffer in the VI channel callback function.
[Definition]
Typedef struct asrVI_IMAGE_BUFFER_S {
IMAGE_BUFFER_S *buffer;
Bool bValid;
Bool bCloseDown;
Uint64_t timestamp;
Uint32_t frameId;
} VI_IMAGE_BUFFER_S;
[Members]
| Buffer | Pointer to the buffer memory structure |
| bValid | Indicates whether the current frame content is valid; if invalid, the upper-level application should discard the current frame |
| bCloseDown | Dedicated for RAW DATA channel; before disabling the RAW DATA channel, a bCloseDown signal must be received in the buffer callback |
| timeStamp | Indicates the timestamp of the current frame |
| frameId | Indicates the frame number of the current frame, starting from 0 |
VIU_GET_RAW_CHN
[Description]
Defines the channel number for obtaining RAW DATA.
[Definition]
#define VIU_GET_RAW_CHN(ViDev, RawChn) do{
RawChn = VIU_MAX_CHN_NUM + ViDev;
}while(0)
VIU_MAX_CHN_NUM
[Description]
Defines the maximum number of VI channels.
[Definition]
#define VIU_MAX_CHN_NUM (VIU_MAX_PHYCHN_NUM)
VIU_MAX_PHYCHN_NUM
[Description]
Defines the maximum number of VI physical channels.
[Definition]
#define VIU_MAX_PHYCHN_NUM 2
VIU_MAX_RAWCHN_NUM
[Description]
Define the maximum number of RAW DATA channels that can be obtained.
[Syntax]
#define VIU_MAX_RAWCHN_NUM 2
VIU_MAX_DEV_NUM
[Description]
Define the maximum number of video input devices.
[Syntax]
#define VIU_MAX_DEV_NUM 2
VIU_DEV_MIN_WIDTH
[Description]
Define the minimum width of the image captured by the VI device.
[Syntax]
#define VIU_DEV_MIN_WIDTH 256
VIU_DEV_MIN_HEIGHT
[Description]
Define the minimum height of the image captured by the VI device.
[Syntax]
#define VIU_DEV_MIN_HEIGHT 144
VIU_DEV_MAX_WIDTH
[Description]
The maximum width of the image captured by the VI device.
[Syntax]
#define VIU_DEV_MAX_WIDTH 2688
VIU_DEV_MAX_HEIGHT
[Description]
The maximum height of the image captured by the VI device
[Syntax]
#define VIU_DEV_MAX_HEIGHT 1944
VIU_CHN_MIN_WIDTH
[Description]
The minimum width supported by the VI physical channel
[Syntax]
#define VIU_CHN_MIN_WIDTH VIU_DEV_MIN_WIDTH
VIU_CHN_MIN_HEIGHT
[Description]
The minimum height supported by the VI physical channel.
[Syntax]
#define VIU_CHN_MIN_HEIGHT VIU_DEV_MIN_HEIGHT
VIU_CHN_MAX_WIDTH
[Description]
The maximum width supported by the VI physical channel.
[Syntax]
#define VIU_CHN_MAX_WIDTH VIU_DEV_MAX_WIDTH
VIU_CHN_MAX_HEIGHT
[Description]
The maximum height supported by the VI physical channel.
[Syntax]
#define VIU_CHN_MAX_HEIGHT VIU_DEV_MAX_HEIGHT
CPP API
This section introduces the usage of the ASR MARS11-ISP CPP module API. The described APIs are all application-oriented in the CPP SDK, and the related parameter data structures, error codes, and return values are explained in detail
API
The CPP module provides the following APIs to users:
- cam_cpp_create_grp: Create a CPP module group.
- cam_cpp_destroy_grp: Destroy a CPP module group.
- cam_cpp_start_grp: Enable the cam cpp module.
- cam_cpp_stop_grp: Disable the cam cpp module.
- cam_cpp_post_buffer: Users send data to CPP.
- cam_cpp_set_callback: Users set a callback function.
- cam_cpp_get_grp_attr: Get CPP Group attributes.
- cam_cpp_set_grp_attr: Set CPP Group attributes.
- cam_cpp_get_tuning_param: Get tuning parameters of the CPP Group.
- cam_cpp_set_tuning_param: Set tuning parameters of the CPP Group.
- cam_cpp_load_settingfile: Tuning debugging interface, load firmware setting file.
- cam_cpp_save_settingfile: Tuning debugging interface, save firmware setting file.
- cam_cpp_read_fw: Debugging interface, get parameters of the CPP Group Firmware module.
- cam_cpp_write_fw: Tuning debugging interface, set parameters of the CPP Group Firmware module.
- cam_cpp_read_reg: Tuning debugging interface, get register values of the CPP Hardware.
- cam_cpp_write_reg: Tuning debugging interface, set register values of the CPP Hardware.
- cam_cpp_dump_frame: Save the output and corresponding input images of the group to a specified directory.
cam_cpp_create_grp
[Description]
Create a cam CPP module group.
[Syntax]
int32_t cam_cpp_create_grp(uint32_t grpId);
[Parameters]
| grpId | CPP group ID. Range: [0, CPP_GRP_MAX_NUM) | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
cam_cpp.h - Library file:
libcpp.so
[Note]
- Duplicate creation is not supported.
[Related Operations]
cam_cpp_destroy_grp
cam_cpp_destroy_grp
[Description]
Destroy a cam CPP module group.
[Syntax]
int32_t cam_cpp_destroy_grp(uint32_t grpId);
[Parameters]
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- The CPP group must have been created.
cam_cpp_stop_grpmust be called to disable this group. - When calling this interface, it will wait for the current task of this group to finish processing before truly destroying it.
cam_cpp_create_grp
cam_cpp_start_grp
[Description]
Start the cam CPP module.
[Syntax]
int32_t cam_cpp_start_grp(uint32_t grpId);
[Parameters]
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- Repeatedly calling this function to set the same group returns success.
cam_cpp_stop_grp
cam_cpp_stop_grp
[Description]
Disable the cam CPP module group.
[Syntax]
int32_t cam_cpp_stop_grp(uint32_t grpId);
[Parameters]
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- Buffers sent to the cpp group via the
cam_cpp_post_bufferinterface will be returned during the stop process.
cam_cpp_start_grp
cam_cpp_post_buffer
[Description]
The user sends a frame of image data to the CPP module.
[Syntax]
int32_t cam_cpp_post_buffer(
uint32_t grpId,
const IMAGE_BUFFER_S *inputBuf,
const IMAGE_BUFFER_S *outputBuf,
int32_t frameId,
FRAME_INFO_S *frameInfo
[Parameters]
| inputBuf | Information of the input image. For details, see IMAGE_BUFFER_S. | Input |
| outputBuf | Information of the output image. For details, see IMAGE_BUFFER_S. | Output |
| frameInfo | For details, see FRAME_INFO_S. | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header files:
cam_cpp.h,cam_module_interface.h - Library file:
libcpp.so
[Note]
- The group must have been created.
cam_cpp_ReturnBuffer
[Description]
The user sets the callback function.
[Syntax]
int32_t cam_cpp_set_callback(
uint32_t grpId,
CppCallback callback
[Parameters]
| callback | This interface is called when the module has finished processing and the output image is ready. | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
[Description]
Get the attributes of the CPP group.
[Syntax]
int32_t cam_cpp_get_grp_attr(
uint32_t grpId,
CPP_GRP_ATTR_S *attr
[Parameters]
| attr | Pointer to the CPP group attributes | Output |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- The group attributes must be valid. Static attributes cannot be dynamically set. For details, see
CPP_GRP_ATTR_S.
[Description]
Set the attributes of the CPP group.
[Syntax]
int32_t cam_cpp_set_grp_attr(
uint32_t grpId,
const CPP_GRP_ATTR_S *attr
[Parameters]
| attr | Pointer to the CPP group attributes | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
CPP_GRP_ATTR_S.
[Description]
Get the tuning parameters of the CPP Group.
[Syntax]
int32_t cam_cpp_get_tuning_param(
uint32_t grpId,
cpp_tuning_params_t *tuningParam
[Parameters]
| tuningParam | Pointer to the module tuning parameters | Output |
[Return Values]
| 0 | Success |
[Requirements]
- Header files:
cam_cpp.h,CPPGlobalDefine.h - Library file:
libcpp.so
[Note]
[Description]
Set the tuning parameters of the CPP Group.
[Syntax]
int32_t cam_cpp_set_tuning_param(
uint32_t grpId,
[Parameters]
| tuningParam | Pointer to the module tuning parameters | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header files:
libcpp.so
[Note]
[Description]
[Syntax]
int32_t cam_cpp_load_settingfile(
uint32_t grpId,
const char *fileName
[Parameters]
| fileName | Pointer to the path of the cpp firmware configuration file | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
[Description]
[Syntax]
int32_t cam_cpp_save_settingfile(
uint32_t grpId,
[Parameters]
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
cam_cpp_read_fw
[Description]
Tuning debugging interface, get parameters of the CPP Group Firmware module.
[Syntax]
int32_t cam_cpp_read_fw(
uint32_t grpId,
const char *filter,
const char *param,
uint32_t row,
uint32_t column,
int32_t *pVal
[Parameters]
| filter | Pointer to the name of the Firmware Filter | Input |
| param | Pointer to the name of the Firmware Parameter | Input |
| row | Row offset of the Firmware Parameter element | Input |
| column | Column offset of the Firmware Parameter element | Input |
| pVal | Pointer to the list of Firmware Parameter elements | Output |
[Return Values]
| -1 | Failure. Check the input parameter names. |
| 0 | Failure. No parameter value was obtained. |
| Positive values | Success. Indicates the number of elements obtained for the parameter. 1 for a single element, >1 for multiple elements |
[Requirements]
- Header file:
libcpp.so
[Note]
cam_cpp_write_fw
cam_cpp_write_fw
[Description]
[Syntax]
int32_t cam_cpp_write_fw(
uint32_t grpId,
const char *pFilterName,
const char *pParamName,
uint32_t row,
uint32_t column,
int32_t val
[Parameters]
| s32Val | Value of the Firmware Parameter element | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
cam_cpp_read_fw
cam_cpp_read_reg
[Description]
Tuning debugging interface, get the value of the CPP Hardware register.
[Syntax]
int32_t cam_cpp_read_reg(
uint32_t addr,
uint32_t *val
[Parameters]
| addr | Hardware register address | Input |
| val | Hardware register value | Output |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- There is only one set of hardware register resources, and the lower 16-bit specifies the address offset.
cam_cpp_write_reg
cam_cpp_write_reg
[Description]
Tuning debugging interface, set the value of the CPP Hardware register.
[Syntax]
int32_t cam_cpp_write_reg(
uint32_t addr,
uint32_t val,
uint32_t mask
[Parameters]
| val | Hardware register value | Input |
| mask | Hardware register mask | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
cam_cpp_read_reg
cam_cpp_dump_frame
[Description]
Save the input and output images of the specified number of frames for the group to the specified directory.
[Syntax]
int32_t cam_cpp_dump_frame(
uint32_t grpId,
const char *path,
uint32_t count
[Parameters]
| path | Specified dump directory, cannot be NULL | Input |
| count | Number of consecutive frames to be dumped | Input |
[Return Values]
| 0 | Success |
[Requirements]
- Header file:
libcpp.so
[Note]
- This API is an asynchronous operation. After returning success, it will continuously dump the specified number of frames starting from that moment. If the specified number of frames has not been dumped yet, calling this interface again will interrupt the previous operation and start the current operation.
None
Data Types
The data types related to the CPP module are defined as follows:
- CPP_GRP_MAX_NUM: Defines the maximum number of CPP GROUPs.
- CPP_MIN_IMAGE_WIDTH: Defines the minimum width of the CPP image.
- CPP_MIN_IMAGE_HEIGHT: Defines the minimum height of the CPP image.
- CPP_MAX_IMAGE_WIDTH: Defines the maximum width of the CPP image.
- CPP_MAX_IMAGE_HEIGHT: Defines the maximum height of the CPP image.
- CPP_GRP: Defines the CPP group number.
- CPP_MOD_ID_E: Defines the CPP submodule ID.
- CPP_GRP_ATTR_S: Defines the attributes of the CPP GROUP.
- CPP_GRP_NR_ATTR_S: Defines the NR attributes of the CPP GROUP.
- CPP_GRP_EE_ATTR_S: Defines the EE attributes of the CPP GROUP.
- CPP_GRP_TNR_ATTR_S: Defines the TNR attributes of the CPP GROUP.
CPP_GRP_MAX_NUM
[Description]
Defines the maximum number of CPP Groups.
[Definition]
#define CPP_GRP_MAX_NUM (16)
[Member Variables]
None
[Note]
None
[Related Types and Data Structures]
None
CPP_MIN_IMAGE_WIDTH
[Description]
Defines the minimum width of the image supported by the CPP module.
[Definition]
#define CPP_MIN_IMAGE_WIDTH (480)
[Member Variables]
None
[Note]
None
None
[Description]
Defines the minimum height supported by the CPP image.
[Definition]
#define CPP_MIN_IMAGE_HEIGHT (288)
[Member Variables]
None
[Note]
None
None
CPP_MAX_IMAGE_WIDTH
[Description]
Defines the maximum width supported by the CPP image.
[Definition]
#define CPP_MAX_IMAGE_WIDTH (4224)
[Member Variables]
None
[Note]
None
None
[Description]
[Definition]
#define CPP_MAX_IMAGE_HEIGHT (3136)
[Member Variables]
None
[Note]
None
None
CPP_MOD_ID_E
[Description]
[Definition]
typedef enum {
CPP_ID_3DNR,
CPP_ID_MAX,
} CPP_MOD_ID_E
[Member Variables]
None
[Note]
None
None
CPP_GRP_ATTR_S
[Description]
Defines the attributes of the CPP Group.
[Definition]
typedef struct asrCPP_GRP_ATTR_S {
uint32_t width;
uint32_t height;
PIXEL_FORMAT_E format;
CPP_GRP_WORKMODE_E mode;
} CPP_GRP_ATTR_S;
[Member Variables]
| Variable | Description |
| width, height | Dimensions of the input image. Valid range for width: [CPP_MIN_IMAGE_WIDTH, CPP_MAX_IMAGE_WIDTH]. Valid range for height: [CPP_MIN_IMAGE_HEIGHT, CPP_MAX_IMAGE_HEIGHT]. These are static attributes, meaning they cannot be dynamically modified after the group is created. |
| format | Format of the output image. This is a static attribute, meaning it cannot be dynamically modified after the group is created. |
| mode | Operating mode |
[Note]
- The input image dimensions must be configured according to the actual width and height of the CPP operation. The TNR KGain buffer and output image buffer are allocated based on the input image dimensions. The input image format only supports YUV data.
PIXEL_FORMAT_ECPP_GRP_WORKMODE_E
CPP_GRP_WORKMODE_E
[Description]
Defines the working mode of the CPP Group.
[Definition]
typedef enum {
CPP_GRP_FRAME_MODE,
CPP_GRP_SLICE_MODE,
CPP_GRP_MODE_MAX,
} CPP_GRP_WORKMODE_E;
[Member Variables]
| CPP_GRP_FRAME_MODE | Data is processed on a per-frame basis, with high hardware processing priority |
| CPP_GRP_SLICE_MODE | Data is divided and processed in slices, with low hardware processing priority |
[Note]
None
None
Error Codes
Refer to the Standard C library header file errno.h
tuningtools API
This section introduces the usage of the ASR MARS11-ISP tuningtools module API, and provides detailed explanations of the related parameter data structures and return values.
API
The tuningtools module provides the following APIs to users:
- ASR_TuningAssistant_Create: Create a tuning Assistant.
- ASR_TuningAssistant_Destroy: Destroy a tuning Assistant.
[Description]
Create a tuningtool Assistant.
[Syntax]
ASR_TUNING_ASSISTANT_HANDLE
ASR_TuningAssistant_Create(const ASR_TUNING_ASSISTANT_TRIGGER_S *trigger);
[Parameters]
| trigger | Configuration parameters for the tuning assistant | Input |
[Return Values]
| Non-NULL | Success, returns a pointer to the assistant handle |
| NULL | Failure |
[Requirements]
- Header file:
asr_cam_tuning_assistant.h - Library file:
libtuningtools.so
[Note]
- The structure of
ASR_TUNING_ASSISTANT_TRIGGER_Sis described in the next section on data types.
[Description]
Destroy a tuningtool Assistant.
[Syntax]
bool ASR_TuningAssistant_Destroy(ASR_TUNING_ASSISTANT_HANDLE handle);
[Parameters]
| handle | Pointer to the tuningassistant structure to be destroyed, must be the return value of ASR_TuningAssistant_Create | Input |
[Return Values]
| true | Success |
| false | Failure |
[Requirements]
- Header file:
libtuningtools.so
[Note]
- Duplicate destruction is not supported.
Data Types
[Description]
Defines the tuning assistant handler pointer.
[Definition]
typedef void *ASR_TUNING_ASSISTANT_HANDLE;
[Members]
None
[Note]
None
None
TUNING_MODULE_TYPE_E
[Description]
Defines the types of supported tuning modules.
[Definition]
typedef enum TUNING_MODULE_TYPE {
TUNING_MODULE_TYPE_ISP,
TUNING_MODULE_TYPE_CPP,
TUNING_MODULE_TYPE_ALGO,
TUNING_MODULE_TYPE_MAX
} TUNING_MODULE_TYPE_E;
[Members]
| TUNING_MODULE_TYPE_ISP | ISP module type |
| TUNING_MODULE_TYPE_CPP | CPP module type |
| TUNING_MODULE_TYPE_ALGO | Algorithm module type (users do not need to concern themselves with this) |
| TUNING_MODULE_TYPE_MAX | Maximum number of tunable module types |
[Note]
None
None
TUNING_BUFFER_S
[Description]
Defines the buffer structure used when the tuning module enables the dump raw image feature.
[Definition]
typedef struct TUNING_BUFFER {
uint32_t frameId;
uint32_t length;
void *virAddr;
} TUNING_BUFFER_S, *TUNING_BUFFER_S_PTR;
[Members]
| frameId | Image frame ID |
| length | Length of the image buffer |
| virAddr | Starting address of the image buffer |
[Note]
- Used in conjunction with
ASR_TUNING_ASSISTANT_TRIGGER_Sas one of the input parameters forStartDumpRaw.
None
TUNING_MODULE_OBJECT_S
[Description]
Defines the basic information of a single module entity to be tuned.
[Definition]
typedef struct TUNING_MODULE_OBJECT {
TUNING_MODULE_TYPE_E type;
void *moduleHandle;
uint32_t groupId;
uint8_t dumpRaw;
char name[32];
int (*loadSettingFile)(void *handle, const char *filename);
int (*saveSettingFile)(void *handle, const char *filename);
int (*saveFilterSettingFile)(void *handle, const char *filtername, const char *filename);
int (*readFirmware) (void *handle, const char *filter, const char *param, int32_t row, int32_t colum, int32_t *pVal);
int (*writeFirmware) (void *handle, const char *filter, const char *param, int32_t row, int32_t colum, int32_t val);
} TUNING_MODULE_OBJECT_S, *TUNING_MODULE_OBJECT_S_PTR;
[Members]
| type | Type of the module to be tuned |
| moduleHandle | Handle pointer of the module to be tuned. For algorithm modules, this is used. For ISP and CPP types, it is implemented internally by tuningtools and does not need to be concerned with. |
| groupId | Group ID of the module to be tuned. For ISP type, the range is [0, 1]. For CPP type, the range is [0, 15]. |
| dumpRaw | Whether to support dumping RAW image data |
| name | Name of the module to be tuned |
| loadSettingFile | For algorithm modules, this is the callback for loading setting files. For ISP and CPP, it is implemented internally by tuningtools and does not need to be concerned with. |
| saveSettingFile | For algorithm modules, this is the callback for saving setting files. For ISP and CPP, it is implemented internally by tuningtools and does not need to be concerned with. |
| saveFilterSettingFile | For algorithm modules, this is the callback for saving a specific filter setting file. For ISP and CPP, it is implemented internally by tuningtools and does not need to be concerned with. |
| readFirmware | For algorithm modules, this is the callback for reading a specific filter value. For ISP and CPP, it is implemented internally by tuningtools and does not need to be concerned with. |
| writeFirmware | For algorithm modules, this is the callback for setting a specific filter value. For ISP and CPP, it is implemented internally by tuningtools and does not need to be concerned with. |
[Note]
- When tuning ISP and CPP, focus on
type,groupId, andname.dumpRawis generally set to0.
None
[Description]
Defines the basic callback for the collection of all modules to be tuned.
[Definition]
typedef struct ASR_TUNING_ASSISTANT_TRIGGER {
uint32_t (*GetModuleCount)();
int32_t (*GetModules)(uint32_t moduleCount, TUNING_MODULE_OBJECT_S *modules);
int32_t(*StartDumpRaw)(TUNING_MODULE_TYPE_Etype,uint32_tgroupId,uint32_t frameCount, TUNING_BUFFER_S *frames);
int32_t (*EndDumpRaw)(TUNING_MODULE_TYPE_E type, uint32_t groupId);
} ASR_TUNING_ASSISTANT_TRIGGER_S, *ASR_TUNING_ASSISTANT_TRIGGER_S_PTR;
[Members]
| GetModuleCount | Returns the total number of modules to be tuned |
| GetModules | Obtains a list of moduleCount modules to be tuned (placed in the modules array), and returns the actual number of modules obtained |
| StartDumpRaw | Callback to start rawdump, not recommended for use |
| EndDumpRaw | Callback to end rawdump, not recommended for use |
[Note]
- When tuning ISP and CPP, the members of
TUNING_MODULE_OBJECT_Sshould be determined based on the actual ISP and CPPgroupIdused. You can refer to the usage indemo/online_pipeline_test.cunder thetuning_server_init()function.
None
