Adapting AMD Graphics Cards on the K1 Platform
This document provides guidance for developers adapting AMD graphics cards for the K1 platform, using the Radeon HD7350 as an example. It outlines key modifications to the Linux kernel and explains the rationale behind each change.
Background Introduction
The discrete GPU drivers in the Linux kernel rely on the DRM (Direct Rendering Manager) subsystem.
DRM is a kernel module used to manage GPU (Graphics Processing Unit) resources, providing a unified interface to support graphics cards from different vendors.
The overall DRM structure consists of the following layers:
User Space Interface
Interacts with user-space graphics libraries (such as Mesa, X.Org, Wayland) via interfaces likeioctl.
Applications can access the GPU through these libraries.
Interaction flow: Application → Graphics Library → DRMioctl→ DRM Driver → GPU -
DRM Core Layer
Provides a standardized framework and common functionalities, including GPU device initialization, resource allocation, memory management, task scheduling and synchronization, as well as communication interfaces between user space and kernel space.-
GEM (Graphics Execution Manager)
- Manages graphics memory objects
- Supports efficient allocation and sharing of video memory
- Allows user-space applications to create and manage graphic buffers for efficient rendering
TTM (Translation Table Maps)
- Responsible for mapping and managing video memory and system memory; can serve as the backend for GEM
- Provides resource scheduling and allocation strategies under memory pressure
Command Scheduling
- Manages GPU multitasking scheduling
- Coordinates the order of operations between kernel space and user space using mechanisms like Fence to avoid resource conflicts
VRAM Management
- Handles allocation, mapping, and recycling of video memory
- Supports Zero-Copy technology to reduce data transfer overhead between kernel and user space
Hardware-Specific Driver Modules
- Responsible for hardware control of GPUs from different vendors and models
- Typical drivers:
nouveau(open-source NVIDIA driver),amdgpuandradeon(AMD drivers)
Structure diagram of the radeon driver:
Configuration and Modifications
When adapting an AMD graphics card to the K1 platform, modifications and adjustments are required in areas such as the graphics driver, Device Tree, address mapping, cache strategy, DMA bit width, and interrupt management.
For RISC-V architecture platforms, these adjustments should be made with a thorough understanding of the memory management mechanism and PCIe address space mapping.
This reference document will cover the following aspects:
- Device Tree parsing and address mapping
- Adding write-combining support
- Cache attributes and access permission adjustments
- DMA address width adaptation
- MSI interrupt support limitations
- Linux kernel GPU driver configuration
Device Tree and Address Mapping
Device Tree Parsing:
- In the Device Tree, the
rangesproperty defines the mapping relationship between the address space of child devices and that of the parent device. - In a PCIe host controller node, the
rangesproperty typically contains four parts:
<address properties, PCIe address, CPU address, address length>
Example modification:
diff --git a/arch/riscv/boot/dts/spacemit/k1-x.dtsi b/arch/riscv/boot/dts/spacemit/k1-x.dtsi
index 7ea166ca6fb0..fd978a379c37 100644
--- a/arch/riscv/boot/dts/spacemit/k1-x.dtsi
+++ b/arch/riscv/boot/dts/spacemit/k1-x.dtsi
@@ -2198,7 +2198,8 @@ pcie2_rc: pcie@ca800000 {
#address-cells = <3>;
#size-cells = <2>;
ranges = <0x01000000 0x0 0xb7002000 0 0xb7002000 0x0 0x100000>,
- <0x02000000 0x0 0xa0000000 0 0xa0000000 0x0 0x17000000>;
+ <0x42000000 0x0 0xa0000000 0 0xa0000000 0x0 0x10000000>,
+ <0x02000000 0x0 0xb0000000 0 0xb0000000 0x0 0x7000000>;
interconnects = <&dram_range2>;
interconnect-names = "dma-mem";
Before the change:
- Source address
0xa0000000→ Destination address0xa0000000 - Size
0x17000000(368 MB), attribute: MEM
- Source address
After the change:
- 1st segment: Source address
0xa0000000→ Destination address0xa0000000, size0x10000000(256 MB), attribute: MEM + Prefetchable - 2nd segment: Source address
0xb0000000→ Destination address0xb0000000, size0x7000000(112 MB), attribute: MEM
This adjustment splits the large VRAM region, with part of it set as prefetchable to improve access performance.
Note
- The total available address space for pcie2 on the K1 platform is 384MB, including configuration space and BAR space.
- When modifying the Device Tree, refer to the BAR address range of the existing GPU and appropriately divide the mapped regions.
Adding wc (write-combining) Support
diff --git a/arch/riscv/include/asm/pci.h b/arch/riscv/include/asm/pci.h
index cc2a184cfc2e..9f6f59aff214 100644
--- a/arch/riscv/include/asm/pci.h
+++ b/arch/riscv/include/asm/pci.h
@@ -27,6 +27,10 @@ static inline int pcibus_to_node(struct pci_bus *bus)
#endif
#endif /* defined(CONFIG_PCI) && defined(CONFIG_NUMA) */
+#if defined(CONFIG_SOC_SPACEMIT_K1X)
+#define arch_can_pci_mmap_wc() 1
+#endif
/* Generic PCI */
#include <asm-generic/pci.h>
- Enable write-combining (WC) in the PCI address mapping on the K1 platform.
- WC mode requires the resource to have the IORESOURCE_PREFETCH flag set.
- Together with Device Tree modifications, WC can be enabled when PCI resources are mapped to user space, improving VRAM access efficiency.
Cache Attributes and Access Permission Settings
In AMD GPU adaptation, the cache strategy directly affects both VRAM access efficiency and system stability.
By default, the driver selects from several caching modes based on rbo->flags, such as:
- uncached (no caching)
- cached (normal caching)
- write-combined (WC)
However, the default strategy is not always optimal for GPU VRAM access patterns, so modifications are necessary.
Modification Example
In the radeon_ttm_tt_create function, force the use of write-combined (WC):
diff --git a/drivers/gpu/drm/radeon/radeon_ttm.c b/drivers/gpu/drm/radeon/radeon_ttm.c
index 4eb83ccc4906..4693119e2412 100644
--- a/drivers/gpu/drm/radeon/radeon_ttm.c
+++ b/drivers/gpu/drm/radeon/radeon_ttm.c
@@ -512,6 +512,8 @@ static struct ttm_tt *radeon_ttm_tt_create(struct ttm_buffer_object *bo,
caching = ttm_cached;
+ caching = ttm_write_combined;
if (ttm_sg_tt_init(>t->ttm, bo, page_flags, caching)) {
kfree(gtt);
return NULL;
Extend RISC-V Architecture Support
Add support for RISC-V in the TTM module to ensure the WC mode works correctly:
diff --git a/drivers/gpu/drm/ttm/ttm_module.c b/drivers/gpu/drm/ttm/ttm_module.c
index b3fffe7b5062..1319178edf03 100644
--- a/drivers/gpu/drm/ttm/ttm_module.c
+++ b/drivers/gpu/drm/ttm/ttm_module.c
@@ -74,7 +74,8 @@ pgprot_t ttm_prot_from_caching(enum ttm_caching caching, pgprot_t tmp)
#endif /* CONFIG_UML */
#endif /* __i386__ || __x86_64__ */
#if defined(__ia64__) || defined(__arm__) || defined(__aarch64__) || \
- defined(__powerpc__) || defined(__mips__) || defined(__loongarch__)
+ defined(__powerpc__) || defined(__mips__) || defined(__loongarch__) \
+ || defined(__riscv)
if (caching == ttm_write_combined)
tmp = pgprot_writecombine(tmp);
Explanation:
- On the RISC-V platform, when the cache mode is write-combined (i.e.,
caching = ttm_write_combined), the PTE (Page Table Entry) is correctly set to non-cached or write-combined attributes. - This avoids cache incoherence issues during VRAM access and improves rendering and data transfer efficiency.
RISC-V architecture support is introduced in the ttm_prot_from_caching function. When caching = ttm_write_combined, the corresponding page table attributes are set to write-combined mode. On RISC-V platforms, when the cache attribute is write-combined, the corresponding PTE is correctly set as non-cached or write-combined.
DMA Address Width (dma_bits) Adjustment
During driver initialization, dma_bits is used to specify the size of the physical memory space addressable by the GPU.
diff --git a/drivers/gpu/drm/radeon/radeon_device.c b/drivers/gpu/drm/radeon/radeon_device.c
index afbb3a80c0c6..42e6510eccf0 100644
--- a/drivers/gpu/drm/radeon/radeon_device.c
+++ b/drivers/gpu/drm/radeon/radeon_device.c
@@ -1361,7 +1361,7 @@ int radeon_device_init(struct radeon_device *rdev,
* AGP - generally dma32 is safest
* PCI - dma32 for legacy pci gart, 40 bits on newer asics
- dma_bits = 40;
+ dma_bits = 32;
if (rdev->flags & RADEON_IS_AGP)
dma_bits = 32;
if ((rdev->flags & RADEON_IS_PCI) &&
- During driver initialization, the original code defaults to
dma_bits = 40, meaning the GPU can access up to 1TB of memory space (40-bit addressing). - For adaptation on the K1 platform, the value is changed to
dma_bits = 32to improve stability, limiting the accessible range to within 4GB (32-bit addressing).
This modification improves compatibility and stability when loading the Radeon driver on the K1 platform. It is recommended to closely monitor related address access behavior during debugging.
Note:
For other AMD GPUs, if the GPU itself does not require accessing a large physical memory space, thedma_bitsvalue can be adjusted accordingly to ensure proper device operation.
MSI Interrupt Adaptation
On the K1 platform, some older AMD GPU architectures (especially GCN1 and earlier) may experience issues where MSI (Message Signaled Interrupts) fail to trigger interrupts correctly.
To ensure system stability, MSI can be disabled in the driver, reverting to the traditional legacy interrupt method.
diff --git a/drivers/gpu/drm/radeon/radeon_irq_kms.c b/drivers/gpu/drm/radeon/radeon_irq_kms.c
index c4dda908666c..f540529909d3 100644
--- a/drivers/gpu/drm/radeon/radeon_irq_kms.c
+++ b/drivers/gpu/drm/radeon/radeon_irq_kms.c
@@ -244,6 +244,10 @@ static bool radeon_msi_ok(struct radeon_device *rdev)
/* MSIs don't work on AGP */
return false;
+#if IS_ENABLED(CONFIG_SOC_SPACEMIT_K1X)
+ /* Chips <= GCN1 cannot get MSI to work on K1 */
+ return false;
+#endif
* Older chips have a HW limitation, they can only generate 40 bits
Note:
- If the GPU cannot trigger interrupts, or system interrupts behave abnormally after inserting the GPU, try disabling MSI.
- Disable MSI only when necessary:
- Disabling MSI → higher stability, but performance and latency may be slightly affected.
- Enabling MSI → better performance and latency, but may be unstable on the K1 platform.
Enable GPU Driver Configuration
diff --git a/arch/riscv/configs/k1_defconfig b/arch/riscv/configs/k1_defconfig
index 1e14a4a5c4f7..58dfdf05bfce 100644
--- a/arch/riscv/configs/k1_defconfig
+++ b/arch/riscv/configs/k1_defconfig
@@ -881,6 +881,8 @@ CONFIG_SPACEMIT_K1X_SENSOR_V2=y
# CONFIG_DVB_CXD2099 is not set
# CONFIG_DVB_SP2 is not set
# CONFIG_DRM_DEBUG_MODESET_LOCK is not set
+CONFIG_DRM_RADEON=m
+CONFIG_DRM_RADEON_USERPTR=y
CONFIG_DRM_SPACEMIT=y
CONFIG_SPACEMIT_MIPI_PANEL=y
CONFIG_SPACEMIT_HDMI=y
Enable Radeon driver support in the kernel configuration file k1_defconfig:
These configurations can be selected in make menuconfig using the following options:
Y→ built into the kernel (built-in)M→ compiled as a module
Currently, on the K1 platform:
- The radeon driver supports AMD GPUs with architectures before GCN 1.0;
- For GCN 1.0 and later architectures (such as the Radeon Rx series), the amdgpu driver needs to be adapted and enabled.
Note: After modifying or adapting the driver code, make sure the corresponding kernel configuration is enabled.
