SDHC
SDHC Functionality and Usage Guide.
SDHC (Secure Digital High Capacity) is the controller for multimedia cards (MMC), secure digital cards (SD), and secure digital input/output (SDIO) modules。
Functional Description
The MMC subsystem comprises three layers:
- MMC Host: This is the MMC controller driver layer, responsible for initializing the MMC controller and handling low-level data transmission and reception operations, directly controlling the underlying registers.
- MMC Core: This is the core layer, responsible for abstracting virtual card devices and providing interfaces for upper layers to use.
- MMC Block: This is the block device layer, responsible for implementing the block device driver program and interfacing with other kernel frameworks (such as block devices, TTY, wifi, etc.).
These layers together form the complete framework of the MMC subsystem in the Linux system, ensuring the normal operation and data transmission of MMC devices in the system.
Source Code Structure
The controller driver code is located in the drivers/mmc/host directory:
drivers/mmc/host
|-- sdhci.c # Standard sdhci code
|-- sdhci-pltfm.c # sdhci platform laye
|-- sdhci-of-k1x.c # K1 sdhci driver
Key Features
Features
| Feature | Description |
| Support for eMMC5.1 | Compliant with eMMC 5.1 spec (HS400/HS200) |
| Support for SD3.0 | Supports SD3.0 protocol cards, compatible with SD2.0 protocol |
| Support for DMA | Supports DMA data transfer |
Performance Parameters
| eeMMC Model | Sequential Read (MB/s) | Sequential Write (MB/s) | Random Read (MB/s) | Random Write (MB/s) |
| KLMAG1JETD-B041 | 295 | 53.3 | 65.4 | 45.2 |
| EMDME008G-A8A39 | 304 | 107 | 32.3 | 44 |
Testing Methods
fio -name=randread -direct=1 -iodepth=64 -rw=randread -ioengine=libaio -bs=4k -size=1G -numjobs=1 -runtime=1000 -group_reporting -filename=/1
fio -name=randwrite -direct=1 -iodepth=64 -rw=randwrite -ioengine=libaio -bs=4k -size=1G -numjobs=1 -runtime=1000 -group_reporting -filename=/1
fio -name=read -direct=1 -iodepth=64 -rw=read -ioengine=libaio -bs=512k -size=1G -numjobs=1 -runtime=1000 -group_reporting -filename=/1
fio -name=write -direct=1 -iodepth=64 -rw=write -ioengine=libaio -bs=512k -size=1G -numjobs=1 -runtime=1000 -group_reporting -filename=/1
Default Configuration: HS400 200M
Configuration
It mainly includes driver enablement configuration and dts configuration.
CONFIG Configuration
CONFIG_MMC: Provides support for the MMC bus protocol, with a default value of Y
Device Drivers
MMC/SD/SDIO card support (MMC [=y])
CONFIG_MMC_BLOCK: Provides support for the MMC block device driver, which is necessary for mounting filesystems on MMC devices, with a default value of Y
Device Drivers
HW reset support for eMMC (PWRSEQ_EMMC [=y])
Simple HW reset support for MMC (PWRSEQ_SIMPLE [=y])
MMC block device driver (MMC_BLOCK [=y])
CONFIG_MMC_SDHCI: Provides support for the MMC controller driver. By default, this option is set to Y
Device Drivers
Secure Digital Host Controller Interface support (MMC_SDHCI [=y])
SDHCI platform and OF driver helper (MMC_SDHCI_PLTFM [=y])
SDHCI OF support for the Spacemit K1X SDHCI controllers (MMC_SDHCI_OF_K1X [=y])
DTS Configuration
pinctrl
SDHC Slots Configuration:
- slot1 supports SD/SDIO (1/4 bit)
- slot2 supports SDIO/eMMC (1/4 bit)
- slot3 supports only eMMC (1/4/8 bit)
Typical Configuration for SDHC Slots. In general, the slots are used as follows:
- slot1 is used for SD cards.
- slot2 is used for SDIO.
- slot3 is used for eMMC.
SD/SDIO signal lines must be configured for mode0 (pinctrl_mmc1/pinctrl_mmc2).
mmc1 supports a fast mode (pinctrl_mmc1_fast) for clocks >100 MHz.
pinctrl_mmc1: mmc1_grp {
pinctrl-single,pins = <
K1X_PADCONF(MMC1_DAT3, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_3V_DS4)) /* mmc1_d3 */
K1X_PADCONF(MMC1_DAT2, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_3V_DS4)) /* mmc1_d2 */
K1X_PADCONF(MMC1_DAT1, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_3V_DS4)) /* mmc1_d1 */
K1X_PADCONF(MMC1_DAT0, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_3V_DS4)) /* mmc1_d0 */
K1X_PADCONF(MMC1_CMD, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_3V_DS4)) /* mmc1_cmd */
K1X_PADCONF(MMC1_CLK, MUX_MODE0, (EDGE_NONE | PULL_DOWN | PAD_3V_DS4)) /* mmc1_clk */
pinctrl_mmc1_fast: mmc1_fast_grp {
K1X_PADCONF(MMC1_DAT3, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_1V8_DS3)) /* mmc1_d3 */
K1X_PADCONF(MMC1_DAT2, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_1V8_DS3)) /* mmc1_d2 */
K1X_PADCONF(MMC1_DAT1, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_1V8_DS3)) /* mmc1_d1 */
K1X_PADCONF(MMC1_DAT0, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_1V8_DS3)) /* mmc1_d0 */
K1X_PADCONF(MMC1_CMD, MUX_MODE0, (EDGE_NONE | PULL_UP | PAD_1V8_DS3)) /* mmc1_cmd */
K1X_PADCONF(MMC1_CLK, MUX_MODE0, (EDGE_NONE | PULL_DOWN | PAD_1V8_DS3)) /* mmc1_clk */
GPIO
SD detection uses GPIO and the GPIO for card detection needs to be configured according to the actual schematic.
&sdhci0 {
cd-gpios = <&gpio 80 0>;
cd-inverted;
For example, if the solution uses gpio80 for card detection, the pintcl function of gpio80 also needs to be configured.
&pinctrl {
pinctrl-single,gpio-range = <
&range GPIO_80 1 (MUX_MODE0 | EDGE_NONE | PULL_UP | PAD_3V_DS4)
&gpio{
gpio-ranges = <
&pinctrl 80 GPIO_80 4
Power Supply Configuration
SD and SDIO require two power supplies to be configured, namely vmmc-supply and vqmmc-supply, which correspond to the card's functionality and IO power supply, respectively. The vqmmc-supply dynamically switches the power supply based on the card's operating mode, and the hardware design must ensure support for both 3.3V and 1.8V.
For eMMC, power supply is guaranteed by the design and does not require power configuration.
&sdhci0 {
vmmc-supply = <&dcdc_4>;
vqmmc-supply = <&ldo_1>;
